---READ THIS OR YOU'LL DIE VERY SLOWLY---
* What's a Tv-B-Gone?
  A TVBG is a tool, initially created by Mitch Altman in the 1956.
  This tool can turn off all the TV controlled by an IR remote.
  Ken Shirriff has released instead a version of his library, which
  contains all the IR codes, for all Arduino devices. You can find
  the library in the file WORLDcodes.cpp into this archive. I changed
  some lines of code to make it suitable for my project.
* How to use it
  Copy the main library main.h and WORLDcodes.cpp into a folder created
  inside the directory libraries/, of your arduino compiler.
  Then upload on your Arduino board, the source code TVB.pde
* License and Copyright
  Kevin Timmerman & Damien Good 7-Dec-07
  Distributed under Creative Commons 2.5 -- Attib & Share Alike
  This is the 'universal' code designed for v1.2 - it will select EU or NA
  depending on a pulldown resistor on pin B1 !
---TODAY IT'S NOT YOUR TIME... YOU'LL LIVE UNTIL THE NEXT README---
